Forums >> Revit Building >> Technical Support >> 3-d hatch region
I would like to add a diagonal hatch to a floor surface in 3-d. I would like this hatch to behave like a model line in the sense that it exists 3-dimensionally, but I would like to add it line a filled region. My initial thought is to split a face and apply a new material. Before I go through this, does anyone else have a different idea?
Why not add a model hatch to your floor material?
That is what I am looking for. Thanks!
I only want part of the material to be hatched though. Would I have to split the face, and add the unique material with the hatch to the split face that I want hatched?
If you have a different floor material I would use a different floor. So draw the floor that you dont want a hatch only where you want that, then do a different floor where you want the one with the hatch. (Unless you are doing this for a code plan where you are using a hatch for exit coridors, in that case I am not sure how to go about it)
Thanks!
Adjusting the hatch pattern inside of a filled region? |
Fri, Dec 5, 2008 at 11:07:41 PM
Plan Region not shwoing wall hatch?? |
Mon, Jan 14, 2008 at 12:03:30 PM
Using Region (hatch) in Multiple Views |
Wed, Mar 14, 2012 at 8:41:06 AM
HATCH IN FILLED REGION WONT SHOW |
Wed, Oct 1, 2008 at 8:59:52 PM
Show earth hatch in sections, but not in elevations? |
Thu, Oct 29, 2015 at 7:45:46 PM
Members: | 2102286 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
