Forums >> Community >> The Studio >> Using the Fill Pattern as Tiling for Tile Layout, is it possible?
admin
you can use fill patterns for a tile layout...and you can align the pattern lines to any other line. there is a tile fill pattern that comes with revit.
Hiroshi Jacobs
The Catholic University of America |
admin
if you need to move your tile pattern on the floor, you can use the align tool to move the pattern
Hiroshi Jacobs
3 Posts No Rating |
The problem with using a fill pattern is that it is a 2D object, and therfore overlays 3D information. As a result you would have to shape it around things like toilet, bath, sink, etc. Quite tedious. Better to use a split face on the floor and apply a fill pattern to it. This way the tiling is also 3D and so sits UNDER your other objects. As Hiroshi noted already, you can use the align tool to set the pattern to the origin point you want.
Cheers,
Wesley
admin
I think you mean a filled region... fill patterns are applied to materials and filled regions.
Hiroshi Jacobs
3 Posts No Rating |
True, so... when you use a fill PATTERN use it on a SPLIT FACE, not in a fill REGION, and you will get the 3D result I discussed.
Wes
Tiling Layout |
Wed, Oct 6, 2004 at 1:28:50 AM
Clay Roof Tile -Fill Pattern issue |
Sat, Aug 6, 2005 at 5:17:40 PM
Adjust hatching to follow brick courses or tiling for tiling layouts |
Tue, Aug 5, 2008 at 10:14:13 AM
Pattern file creation - Please help! |
Wed, Aug 12, 2015 at 8:23:00 PM
direction on good workflow- split face regions and fill patterns for carpet tile |
Wed, Sep 16, 2009 at 1:09:04 PM
Members: | 2100621 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
