128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> I can't see materilas propertly
Sun, Aug 10, 2008 at 12:56:11 PM | I can't see materilas propertly
alc112
Hi!
I show you my problem:
 As you se, there is a part of the wall wich shows blank (without material) but it is indeed applied.
This also happens in any way, any quality and style view possible and also if I render it.
What can I do? PLease, I need to print a 3d view tomorrow.
 I use RAC 08
thanks a lot
Sun, Aug 10, 2008 at 1:31:40 PM | I can't see materilas propertly
4 Stars: 203 Votes
Alc, don't you have 2 walls in the same place? In that level select with crossing that wall, then go to the "filter" and check if there is one or more walls in the same place.... in the image we can't see the doors too...
Edited on: Sun, Aug 10, 2008 at 1:37:22 PM
Sun, Aug 10, 2008 at 1:44:03 PM | I can't see materilas propertly
alc112
lol
That's true! I had 2 walls
thanks a lot, again Typhon!
By the way, have you got a material to use as glass for curtain walls. (for the munions and glass panels) because it doesn't look very nice after render that.
Sun, Aug 10, 2008 at 2:36:19 PM | I can't see materilas propertly
4 Stars: 203 Votes
You welcome...
Need help creating pattern
Mon, Dec 1, 2008 at 11:05:49 AM
2008 Revit_ White walls rendering grey
Thu, Jul 10, 2008 at 11:31:35 AM
glass transparancy
Wed, Jul 9, 2008 at 6:20:44 AM
How can I paint the wall the color I want?
Wed, Apr 2, 2008 at 11:13:07 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:47 AM
Page generation time: 1.9812
