67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> IES files in Revit
5 Posts No Rating |
Does anyone know if it is possible to rotate the IES photo web. I have an IES file from a manufacturer to make a custom light, unfortunately it is 90 degrees to the 'emit light line'. Does anyone know how to fix this, or do I have to figure out how to modify the raw IES file?
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Does anyone have the answer to this. I have exactly the same thing. The 3D web does not match the project light. I don't know anything about .IES files. Any help would be greatly appreciated.
![brettgoodchild Avatar](user_avatar/14257.jpg)
![4 Stars: 17 Votes](/images/stars_4.gif) |
There should be a property in the lighting family to control the webs direction...sometimes its called Tilt Angle...something along those lines.
The Tilt Angle parameter is not what I need to do. It controls the "tilt" of the web not the rotation in plan.
I am having the same problem, the photometric web and the light source are not in the same orientation. Not the Tilt angle, I am need to rotate the Web perpindicular. Any thoughts on how to break the association to the light source to manipulate?
.ies files from Revit export to 3Ds Max rotate incorrectly |
Wed, Aug 19, 2009 at 2:06:14 PM
SketchUp and IES |
Fri, Aug 29, 2008 at 1:18:34 PM
Lighting and ies files |
Mon, May 12, 2008 at 9:02:14 AM
lighting analyse with IES |
Mon, Apr 28, 2008 at 1:56:56 AM
IES Photometric lighting issue - no light |
Thu, Aug 13, 2009 at 3:30:28 PM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
