Forums >> Revit Structure >> Technical Support >> New column based on concrete column family
2 Posts No Rating |
I'm new to Revit, so this may be a no brainer: I created a new family based on the concrete column family and re-drew a profile in an L shape. I applied listening dimensions in order to be able to adjust the legs of the L in both directions. I set the work plane to Lower Ref. Level, and left the extrusion parameters the same (start at 0', end at 9'). However, when I load the element into a model, no matter what level I'm at it inserts it at 0'-0" and is 9'-0" tall. I can then move it to a different level by adjusting it's parameter, but it will not change height to match the upper level I set. There must be something simple I'm doing wrong. See attached file.
----------------------------------- Justin |
Wait for the video
Hi see this and tell me if that's what do you want, give me a feed back OK? http://screencast.com/t/LvnUCtA3hy
2 Posts No Rating |
Thanks Typhoon. That worked great. And nice job with providing a video. Now I'll be asking you a new qustion every day
You Welcome, anytime, anyware....
If you thought that was impressive you should see the videos at this site > www.CADclips.com . If you look on the upper left hand side there are 100's more free videos .
Really, i don't comment... Edited on: Fri, Aug 8, 2008 at 3:40:03 AM
Edited on: Fri, Aug 8, 2008 at 5:39:04 AM
Concrete pad footing moves with steel column |
Thu, Dec 12, 2013 at 10:58:07 PM
concrete column |
Mon, Oct 15, 2012 at 9:19:47 AM
curtain wall at column |
Tue, Sep 8, 2009 at 12:24:40 PM
Visibility graphics of a structural column |
Mon, Aug 16, 2010 at 8:21:00 AM
How do you create a column that the proportions adjust to the height |
Wed, Feb 25, 2009 at 8:54:53 AM
Members: | 2119468 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
