110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> rac 2008 inconsistant plotting
Thu, Aug 7, 2008 at 11:17:12 AM | rac 2008 inconsistant plotting
rquist
I'VE HAD THIS ON SEVERAL PROJECTS LATELY.
WHEN I PLOT MY SHEETS THAT I'VE SELECTED, THE WHOLE BATCH GOES TO THE PRINTER. GOOD!
ALL BUT ONE PRINTS FINE.  THE ODD DUCK ENDS UP TO MAKING THE T-BLOCK ABOUT AN 1" BIG.  BAD!!
ANY THOUGHTS WHERE I COULD START TO CORRECT THIS?  IT'S KIND OF ANNOYING.
I END UP SELECTING ONLY THAT SHEET ON ANOTHER PRINT SESSION AND PLOT THE "VISIBLE PORTION OF CURRENT WINDOW.
Tue, Aug 19, 2008 at 10:50:21 PM | rac 2008 inconsistant plotting
psymon
psymon Avatar
3.5 Stars: 6 Votes
Sounds Like one of 2 things:
Is it only that sheet in one project - or does this happen in other projects? If it is only in that project:
Firstly, if you print that sheet by itself with "Current Sheet" ticked, does it print the 1" title block?
If it does it probably means that there is some object that is way outside the confines of the title block, a random bit of drawing that is located off the sheet - maybe "zoom extents" when in the view to see if it zooms way out?
The other reason would be a printer driver error most probably. I do not think that it is a problem with Revit as such. We have never had any trouble printing.
Wed, Aug 20, 2008 at 10:45:20 AM | rac 2008 inconsistant plotting
rquist
next time I have the issue I'll try the zoom extents- that makes sense.
thanks
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
RAC 2009 - Text in CAD file is not plotting?
Wed, May 27, 2009 at 9:27:50 AM
Room Separation Lines not plotting properly RAC 2009
Thu, Aug 6, 2009 at 5:47:46 PM
Ramp Error - Line is too short - RAC 2008
Thu, Jan 24, 2008 at 4:20:24 PM
service pack for RAC 2008?
Thu, Dec 20, 2007 at 4:12:59 PM
Page generation time: 1.6596
