65 Users Online (64 Members):
Forums >> Revit Building >> Tips & Tricks >> REA 2009 Background Image when rendering
Dose anyone know how to add a background image (as you could in 200 when rendering an image? The skies are good but I would like to add the photo of the back ground for my project. If it can't be done is there a work around?
You can render your image with White background and then go to the photoshop and "apply" the new background you want...
you can also create an drafting view, import the two images into the drafting view to combine, and the drag the drafting view onto a sheet. you can also do all this directly on the sheet also. but is only simple overlaying and scaling. if you need to do things like matching perspective etc. you will need to use a program like Photoshop. HTH
you dont even really need photoshop at all. Just render your scene with the mental ray sky, export it as a TIFF then insert the image into a drafting view on top of the image you want to use as the background. When exporting to a TIFF Revit makes the ALPHA channel transparent (Mental Ray Sky = alpha channel)
I was able to make it work only by using a PNG, not a TIFF. Hope that helps.
4 Posts No Rating |
any of the two formats (png or tiff) will do.
SIlent,...Solitary,...Empty |
Thank you all for your help, yes that works fine. :-)
you can also create a mass thats the shape and size of the image and place it where you need it. that way you will be able to see it through glass of a house if it was a site image.
When Rendering, background image get realy bad |
Sat, Nov 11, 2006 at 11:54:44 AM
Revit 2009 Rendering with Background Images [ 1 2 ] |
Sat, Aug 1, 2009 at 10:38:10 AM
15
Rendering-Background Image-I don't find that option in Mental Ray |
Fri, Jun 20, 2008 at 10:42:00 AM
Rendering with background image |
Fri, Oct 1, 2010 at 11:09:57 AM
Rendering Background |
Sat, Nov 22, 2008 at 5:42:50 AM
Members: | 2056191 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
