110 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Work Plane Error
21 Posts No Rating |
Hi all dont know what happened here but i was in need to rotate project north RAC2009 and now i cant draw detail lines or anything on elevation views. It gives me the error message as follows "Can't draw because Work Plane is at a very sharp angle in this view. Go to another view or redefine the Work Plane." and when i try to change the work plane it makes no difference. I dint relize this problem before i saved and closed the file so now i just cant undo back to original. Any ideas
----------------------------------- Brett |
ok solved the problem - it apears that when you use the rotate project tool it dosnt rotate the elevation view tags to match so there for you are at right angles to the true view - must be a better way to rotate than...
23 Posts No Rating |
I've got the same problem. Revit 2009. How did you resolve it?
Floor & Work Plane Error Message |
Thu, May 4, 2017 at 8:01:02 PM
Editing Work Plane for Component |
Tue, Nov 23, 2010 at 2:04:10 PM
Set roof or soffit on work plane? |
Mon, Dec 2, 2013 at 12:57:49 PM
14
get rid of current work plane and 3D snapping |
Fri, Nov 10, 2006 at 3:26:52 AM
Orient a view perpendicular to a work plane |
Thu, Dec 17, 2009 at 11:52:39 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
