73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009: Ajustable Section Line Tail
45 Posts No Rating |
Hi all! I want to know, if I want to place a sections that cut the whole buildings and another section that cut just a floor and wall junction, is there a way to make an ajustable tail that show exactly where is the section (long if it cut the whole wall, and short if it cut just a detail). Please refer to the image attached! Please Help!
21 Posts No Rating |
cant you draw the section then change the crop view
Hi, if i understand what do you want, you can also pick in the line of section and in the middle of the line you have a blue icon, if you pick in that the line split in two, then you can "Stretch" the Section line like do you want....
Sorry yes, i think you want want typhoon is saying and that is to be able to stagger the section, to manupulate where the section line draw's through
Folks, I think the question is about tails ....can you have different ones? I believe the answer is you can have different tails defined but I think only one at a time is used in the project. You can cycle through head-tail-nothing.
Gap between section head and tail and middle line |
Mon, Aug 20, 2012 at 8:13:56 AM
REVIT 2009 - CAN A SECTION TAIL BE VARIED WITH AN INSTANCE PARAMETER? |
Sat, Feb 28, 2009 at 9:49:36 AM
Section Tail |
Thu, Jun 21, 2007 at 3:22:22 PM
Section tags not connecting to Tail |
Fri, Aug 17, 2012 at 11:54:04 AM
Section Head/Tail Visibility issue - RAC2008 |
Thu, Jul 30, 2009 at 10:23:10 AM
Members: | 2017220 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
