44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> partition type
83 Posts No Rating |
I am evaluating the possibility of producing a partition type sheet for a set of construction drawings. I figured it could be done in a legend view using legend components and detail components for the top and bottom of the wall. The question is:
is it possible to tag wall layers as you do with other revit objects so that the text description is entered automatically and linked to the actual layer avoiding having to manually enter the text? It would save time and avoid possible mistakes, it seems in the Revit mentality, I just was not able to find the command and I am afraid it is just not there.
Thanks for any advice.
Confirmed fears...
Its not there (that i know of).
ok, thanks. I will start posting in the wishlist forum.
40 Posts No Rating |
How about a work around but could also be cumbersome..... using different wall type and place side by side then just use join geometry to cut any wall hosted alement through out your wall width this way you can tag each layer.
sounds interesting although what would happen to my walls schedules though?
Partition Types for Construction Drawings |
Fri, Feb 8, 2013 at 3:32:02 AM
Groups. Move partition walls, how? |
Tue, Aug 12, 2008 at 3:08:45 PM
Partition Types |
Wed, Jun 18, 2008 at 2:16:51 PM
Partition Wall Abutment Problem |
Tue, May 14, 2013 at 8:18:25 AM
partition type - wish list |
Tue, May 3, 2005 at 11:57:43 PM
Members: | 2069425 | Objects: | 23097 | Forum Posts: | 152259 | Job Listings: | 3 |
