104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exporting Material Properties from Revit Architecture & MEP to IES<VE>
Tue, Aug 5, 2008 at 10:22:18 AM | Exporting Material Properties from Revit Architecture & MEP to IES<VE>
Kobbs
Kobbs Avatar
Afternoon chaps! Had a search through the forum but couldn't seem to find anything matching what I'm after.
I'm trying to find out any information on whether or not it's possible to set up a wall/floor/roof in Revit and have the material properties transfer over to IES <VE> when it's exported via gbxml.
 For example, could I set up a 500mm cavity wall (125mm brick, 125mm air gap, 250mm concrete block) in Revit and then have it's thermal properties automatically transferred to IES <VE> when the model is exported from Revit? Or do you always have to re-assign the construction types manually in IES <VE> after importing a gbxml file?
We are currently using both Revit Architecture 2009 and Revit MEP 2009 as well as a couple of seats of Arch & MEP 2008, importing models into IES <VE> 5.8.2.1
Fri, Nov 7, 2008 at 8:57:21 AM | Exporting Material Properties from Revit Architecture & MEP to IES<VE>
sagarkagathara
sagarkagathara Avatar
I don't think this can be done.
Let's see why.
How do we make materials in Revit ?
We duplicate the default material and assign render appearance and cut patterns. and so on ... bla, bla, bla..
So for Revit, all materials are same with different appearance.
Now what happens when IES detects these materials ?
Where are thermal properties to calculate thermal load ?
Where are glass properties to calculate daylight calculations ?
Are you getting my point ?
Fri, Nov 7, 2008 at 9:24:14 AM | Exporting Material Properties from Revit Architecture & MEP to IES<VE>
Kobbs
Kobbs Avatar
Wow, thanks for the sarcasm, I obviously wasn't aware that the Revit Oracle cruises these boards, so sorry for wasting your valuable time with my valid question oh great one.
Perhaps it was wrong of me to assume that since the gbxml file type is quite capable of transmitting thermal properties, and because you can assign some physical properties to materials in Revit that it might be logical to assume there would be some way of assigning thermal properties to different constructions in Revit to save you having to re-assign that information again in IES. Y'know what BIM being a major selling point of Revit and all.
Fri, Nov 7, 2008 at 10:54:22 AM | Exporting Material Properties from Revit Architecture & MEP to IES<VE>
sagarkagathara
I know how to export gbXML and I've done it many times.
You're missing my point.
But no use of discussing it with such language as you use here.
So if you  think you have a better idea, I'd be glad to know when you succeed in exporting it.
Thanks, REVIT MASTER !
Mon, Apr 6, 2009 at 4:54:40 PM | Exporting Material Properties from Revit Architecture & MEP to IES<VE>
mkinross
My sympathies with Kobbs on this one - I had over expectations of the potential ability of the gbxml file export process.  The link with Revit is best seen as a means of not having to re-build the model in IES - but even then there are problems as the IES model does not always properly interpret non-orthogonal information - a particular problem with exisiting buildings.
lighting analyse with IES
Mon, Apr 28, 2008 at 1:56:57 AM
IES/MEP
Sun, Apr 27, 2008 at 12:59:49 PM
Problems importing Revit model into IES VE
Thu, Jan 6, 2011 at 10:04:15 AM
.ies files from Revit export to 3Ds Max rotate incorrectly
Wed, Aug 19, 2009 at 2:06:15 PM
IES files in Revit
Mon, Feb 6, 2017 at 4:00:15 PM
Page generation time: 3.3602
