117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rotate Door Tags -- Is this possible?
Tue, Aug 5, 2008 at 9:48:58 AM | Rotate Door Tags -- Is this possible?
hyoctane
Again, this is another naggin issue that I'm pretty sure I know the answer... Is is possible to rotate door tags (or any tag for that matter) to any other degree besides 90? I'd love to have 45 or another custom degree, but I haven't found a way... Anyone know if this is possible?
Tue, Aug 5, 2008 at 10:30:22 AM | Rotate Door Tags -- Is this possible?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The only other thing you can do is to have the tag align with the rotation of the element. Open the tag family and go to Settings-->Family Category and Parameters, and click the checkmark button labled "Rotate with Component". Save the family and reload it into your project. This will allow the tag to align with the element.
Wed, Aug 6, 2008 at 3:10:21 AM | Rotate Door Tags -- Is this possible?
tim123
4 Stars: 19 Votes
Edit the door tag family and rotate it in the editor. See attached image.
 Tim
Wed, Aug 6, 2008 at 9:37:50 AM | Rotate Door Tags -- Is this possible?
jbaker
It's easy enough - When you select the door tag, the options bar above the view window gives you the option for the tag to be horizontal or vertical.
 Hope that helps!
Tue, Feb 10, 2009 at 4:56:01 PM | Rotate Door Tags -- Is this possible?
quinn
Attached is a door tag family we made at our office that will allow you to rotate the tag as a (type parameter).  The only problem is having many different angled doors requires many different types but you can rotate the tag anyway you want and place it where you want. Hope this helps.
Edited on: Tue, Feb 10, 2009 at 4:56:39 PM
Tue, Feb 10, 2009 at 4:58:24 PM | Rotate Door Tags -- Is this possible?
quinn
Attached is a door tag family we made at our office that will allow you rotate the tag as a (type parameter).  The only problem is having many different angled doors requires many different types but you can rotate the tag anyway you want and place it where you want. Hope this helps.
Thu, Aug 10, 2017 at 8:35:19 AM | Rotate Door Tags -- Is this possible?
vandeusonj
- This is what you guys need. It looks way better than when you use the preset revit tag option.
Rotate Tags
Thu, Nov 10, 2011 at 12:33:08 PM
Modify Door Tags from a revit liked file
Thu, Mar 29, 2012 at 6:49:28 PM
Door Tags
Mon, May 12, 2014 at 8:31:35 AM
Is it possible to rotate footing / elevation / etc. tags?
Tue, Feb 2, 2010 at 1:28:40 PM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Page generation time: 2.3867
