53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revision Cloud Schedule HELP!
Tue, Apr 19, 2005 at 8:21:07 AM | Revision Cloud Schedule HELP!
jstewart
Can the Revision Cloud schedule show & calculate the total Revision in a column? Not just as a line of its own at the bottom. See attached jpg to see example of how we want it to look. Thanks
Tue, Apr 19, 2005 at 5:41:55 PM | RE: Revision Cloud Schedule HELP!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not that i know of. Personally i found the Revision Cloud Schedule useless as our office convention is to use letters as opposed to numbers and also to have the the schedule grow from the base. We still use text and will continue to do so until this feature is improved. So i'd suggest just leaving a column here to add a text value. HTH.
Wed, Apr 20, 2005 at 7:11:48 AM | RE: Revision Cloud Schedule HELP!
jstewart
Yes after a closer look I have come to the conclusion that the Revision clouds are useless for us as well! We like to erase the last revision bubble while leaving the tag and you cannot do that. Oh well it would have been nice!
Tue, Apr 1, 2008 at 9:35:48 PM | Revision Cloud Schedule HELP!
IsaacHale21
How do you create a revision cloud tag that allows you to use letters instead of numbers? I can replace the parameter used by the label with the 'Mark' parameter, but then I have to enter the 'A' in each tag in the project manually. We are issuing a different addendum and don't want this to get confused with the usual, so we wanted to use letters instead on numbers, but I can't seem to make it work like the usual 'revision number' parameter would work.
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:52 PM
To set up Revision cloud schedule, and add prefix to Revision Number?
Sun, Jul 19, 2020 at 6:35:18 PM
REVISION TAG AND SCHEDULE
Sun, Jul 20, 2014 at 3:09:53 AM
Revision cloud closes revit
Fri, Sep 28, 2012 at 10:47:53 AM
Date & Created By in a family similar to revision cloud.
Mon, Jun 16, 2008 at 11:13:29 AM
Page generation time: 0.4382
