70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adjust hatching to follow brick courses or tiling for tiling layouts
Tue, Aug 5, 2008 at 3:17:04 AM | Adjust hatching to follow brick courses or tiling for tiling layouts
cvedesigns
Hiya
I need to show coursing on my 1/20 and 1/50 layouts. The hatch that manifests thru revit is great but its not following to course. Stacked walls are dead on where they should be in terms of brick coursing, but it seems that the hatch varies from layout to layout.
The same goes for floor and wall tiling. It would be great to be able to adjust the hatch and place it where you want it as you do with the origin command in AutoCAD.
Tue, Aug 5, 2008 at 6:03:54 AM | Adjust hatching to follow brick courses or tiling for tiling layouts
3.5 Stars: 395 Votes
As long as the hatch pattern is 3D - not 2D, you can adjust it.  Just tab/click onto one of the lines and adjust it.  You can even rotate the pattern to an angle.  Simplier the autocad's origin.
Tue, Aug 5, 2008 at 10:14:12 AM | Adjust hatching to follow brick courses or tiling for tiling layouts
lunchtrayrider
3.5 Stars: 7 Votes
you might want to review the difference in your revit help about drafting vs model hatches.  (2d vs 3d)
I like scooters. and motorcycles.
Tiling Layout
Wed, Oct 6, 2004 at 1:28:49 AM
Placing filled regions for tiling in bathrooms
Fri, Jun 10, 2005 at 10:35:11 AM
Tiling windows
Thu, Jan 30, 2014 at 2:20:42 PM
Tiling Seamless Texture Images
Tue, Oct 12, 2004 at 8:08:15 PM
Tiling
Fri, Jun 15, 2007 at 1:17:13 AM
Page generation time: 0.4340
