50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Rendering with 'Radiate'
Mon, Aug 4, 2008 at 11:32:28 AM | Rendering with 'Radiate'
Kurniawan
I' ve tried to rendering with 'radiate'. As I know, radiate is a tool that can make an interior rendering more realistic. But I have a problem there. Please look at this two picture there..
 http://uploads.bizhat.com/file/206332
 http://uploads.bizhat.com/file/207841
The first picture is a basic rendering with raytrace. The second one is rendering with radiate. Look at the difference between this two picture. The second one, when I use radiate, there is some unwanted shadow. Sad
Have I make a mistake when rendering or ...what? I don't know why. Could someone help me please?
Mon, Aug 4, 2008 at 11:56:39 AM | Rendering with 'Radiate'
Had trouble with that site.  Why don't you just post two small images.
Mon, Aug 4, 2008 at 1:29:20 PM | Rendering with 'Radiate'
4 Stars: 203 Votes
Hi, do you use "BEST" quality in Radiosity and Raytrace Settings? how many steps do you calculate (Solution goal) with Radiosity before you render the final image? If you increase that steps you increase the quality of render, If you attach/join geometry around wall/ceiling/soffit connections and in this case with those elements in the image and make sure walls go to floor above, it will reduce/eliminate the dark streaking shadow effect.
Raytrace / Radiate
Wed, Aug 1, 2007 at 3:07:00 PM
Radiate material problems [ 1 2 ]
Sun, Mar 23, 2008 at 2:52:03 PM
18
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Radiate & Glass in Revit Architecture
Thu, Sep 13, 2007 at 9:36:34 AM
Rendering in Revit
Fri, Apr 17, 2009 at 4:32:29 AM
11
Page generation time: 0.7204
