101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Hatch/Fill patterns droping lines when plotting
Fri, Aug 1, 2008 at 12:41:58 AM | Hatch/Fill patterns droping lines when plotting
BrettoH75
Hi all - this has probably been asked already but i cant find anything through the search.
some times when plotting a view with a filled region or surface pattern, a line or 2 will not show up on the plot, its there in the preview and the drawing view. It seem to happen when using a pattern style with vertical lines eg Roof sheet pattern with lines at 75mm centres.
Any ideas on how to fix this as you can imagine it really sicks out like a sore thumb?
Brett
Fri, Aug 1, 2008 at 3:52:32 AM | Hatch/Fill patterns droping lines when plotting
4 Stars: 203 Votes
What version of Revit are you working? Your Plotter? the settings of printer?
Fri, Aug 1, 2008 at 9:27:56 AM | Hatch/Fill patterns droping lines when plotting
If you are printing raster rather than vector, this can happen.
Sun, Aug 3, 2008 at 5:40:21 PM | Hatch/Fill patterns droping lines when plotting
BrettoH75
thanks for the replies
RA 2009 version I have had i happen in 2008 aswell, i have checked plotter setting and they are correct (the plotter is a Canon iPF600 with the following settings - print priority to image [have tryied line drawing/text here], quality to 600dpi & sharpen text on). I have been plotting with raster so i will change that and try again. It doesnt happen everytime thats why i cant be sure of what it is.
Brett
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:01 AM
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:03 PM
Fill Regions not deleting
Thu, Oct 8, 2020 at 3:52:55 PM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:32 PM
wall fill patterns for different wall types and phases
Sun, Apr 24, 2016 at 4:42:59 AM
Page generation time: 0.5692
