25 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> wood trim in revit arch 2009
1 Posts No Rating |
what is the best way to go about placing a wood trim around the bottom edge of a room. i have come across many sections for trim but can not figure out how to place it into the model as a 3d object. thanks
You can go to Structural menu and put a "Wood Beem" around the room you want... can you put some screen shots to figure out what really do you want?
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Do not use a Structural Beam to create architectural wall trim. To model wood trim around a wall face (ie: chair rail, base board, crown molding etc) you should use a wall based linear family and include your trim profile. You can also create and 'in-place' family right on the spot doing a 'solid extrusion'. You can nest the trim profile or sketch it in.
Use wall sweeps. Load the profile and use the sweep. you can adjust it in the properties to make sure it is sitting on the wall not in the wall.
Arch top wood truss |
Thu, Jan 10, 2013 at 7:47:45 AM
REVIT Structure and Architecture for wood framed buildings |
Thu, Apr 18, 2019 at 2:38:02 PM
Solid Wood Door in Curtain Wall ? |
Mon, Aug 31, 2009 at 4:38:07 PM
How to place wood trim profiles on a wall |
Wed, Mar 14, 2007 at 3:52:22 PM
Rendering function greyed out in Revit Arch 2009 |
Mon, Feb 16, 2009 at 4:53:18 AM
Members: | 2025990 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
