31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Unable to print all columns
HI, When i take printout of my plans all the structural columns are not visible. Few of them are coming. Mostle the SHS column are missing. Strutural columns are coming from a link file. I am using Revit Architecture 2009.
Now on the implementation stage.... |
Did you go to VV and see if the "Structural...." are visible (check/unchek)?
Yes they are visible. Only few of them are missing from printout rest all are coming.
What type of view are you printing? From a sheet? Does everything else from the linked file print ? Try changing the view discipline to Coordination? although this ususally only effects walls.
Yes i am printing from sheet. Changing view disclipline is not making any difference. For the moment i have drawn 2d lines over it but there should be some solution. Nyway thanks
Why won't my Filled Regions print? |
Tue, Sep 2, 2008 at 3:38:22 PM
Unable to print .prn or .plt files. |
Thu, Oct 22, 2009 at 2:51:35 PM
Column Visibility in Callout Detail |
Fri, Jul 7, 2006 at 8:17:27 AM
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Members: | 2017920 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
