60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedules and formulas
Wed, Jul 30, 2008 at 6:58:07 PM | Schedules and formulas
everist
3 Stars: 2 Votes
I'm using Revit 2009 and have a question about forulas and schedules. Is there a way to define an if / then function. Take a look at the attached screen shot. I would like to somehow link the "function" field to  the sq. feet per occupant field. If I choose a function, I would like a sq. foot per occupant to automatically be selected for the sq. foot / occupant field.
Wed, Jul 30, 2008 at 9:09:03 PM | Schedules and formulas
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately you cannot include text parameters in schedules.
The best you could do would be to use a number of Yes/No parameters and then create a calculated value that reads
IF(BUSINESS, 100, 0)
Where BUSINESS is a Yes/No Parameter
HTH.
Regards,
Chris.
Thu, Jul 31, 2008 at 10:06:26 AM | Schedules and formulas
everist
3 Stars: 2 Votes
Would you recommend a resource where I could learn about forumlas and some in depth manipulation of Revit schedules?
Tue, Jun 9, 2009 at 11:18:57 AM | Schedules and formulas
malera
Guys i have probably very easy problem, but I am new to Revit
I have a Room schedule where I inserted few columns including calculated room area and Occupancy of people for that room. Now I would like to create a formula that would calculate the occupancy per person. So I go to the Schedule properties – Field tab – Calculated Value and there in a Formula space I write SF(which is the name of the parameter) = Area/Occupancy; however Revit gives me msg of improper use of Boolean expressions. I tried to rename “occupancy” tried to put numbers (cause I have read that Revit doesn’t deal with text) and so on, but nothing works. Would you be able to help me with that?
Thank you very much for all help,
valeriia
Tue, Jun 9, 2009 at 11:59:46 AM | Schedules and formulas
tim123
4 Stars: 19 Votes
It might be the units.  If occupancy is a number then the type of parameter needs to be set to area, as area / number equals area.
Tue, Jun 9, 2009 at 12:53:24 PM | Schedules and formulas
malera
I tried to chanfe units. It still gives me the same message.
Thank you
Adding formulas to schedules
Mon, Nov 5, 2007 at 6:07:50 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:06 PM
14
Formulas and Schedules for Revit
Thu, Sep 13, 2007 at 9:06:08 AM
Formulas for Schedules
Wed, Jul 22, 2009 at 3:31:29 PM
structure analys with Revit
Thu, May 11, 2006 at 12:30:27 PM
Page generation time: 0.8319
