Forums >> Revit Building >> Technical Support >> Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
Wed, Jul 30, 2008 at 7:11:45 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
kyoungblut
So i'm creating a Wall Based Urinal with ADA standards (which locates the object a specific distance above the floor) as well with normal standards, and when i insert it into a project there is some unknown parameter (Elevation) that is locating the position of my object even though i have set one up in the first place (C.L. Outlet) how would i override this and make the family accept my value and not the one in the family. or atleast locate it to give it a formula... something.. anything :S
 I can load my file if needed but hopefully this can be resolved with out.
Wed, Jul 30, 2008 at 8:04:59 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
afc4
3 Stars: 3 Votes
What you are going to need to do is with in the family you have a family types button. What this has is all the parameters that are associated with a given family. So if you created a dimension with a label( lets say its elevation) that label has a distance attached to it and the easiest place to change it is under family types.
Wed, Jul 30, 2008 at 8:09:34 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
4 Stars: 203 Votes
Yeah, you must edit the Urinal family and check that dimension (elevation)....
Wed, Jul 30, 2008 at 8:16:34 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
kyoungblut
my issue is that the Elevation Parameter is not visible in the family, and is only active when inserted into a project, i have loaded the family so that you can see, i've created family types, and parameters for it to be based off of, but this Elevation Parameter overrides everything else, and i can't locate it in the actually family.
Wed, Jul 30, 2008 at 8:36:02 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
afc4
3 Stars: 3 Votes
When you place it in the project you need to change its element properties, the elevations is located there. If you put the elevation to 0 it will use the formulas you entered.
Wed, Jul 30, 2008 at 8:48:03 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
kyoungblut
i guess i'm missing something here, i have attached it into a project, and i changed the value to 0 and well thats what it did, it went to the floor. :S
Wed, Jul 30, 2008 at 9:00:04 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
afc4
3 Stars: 3 Votes
well for some reason in one of the files i brought it into, changing the elevation to 0 it worked. In the case of your file it did bring it to the floor. I guess the work around would be to match the elevation to the height that you want. It doesn't look as the the parameters are totally correct.
Wed, Jul 30, 2008 at 9:03:39 AM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
kyoungblut
could you send me your example that did work? maybe i can figure it out from that :s
Thu, Oct 2, 2008 at 12:08:49 PM | Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
85lho
I have the exact same problem for case-work and generic models and using the elevation property which is an instance parameter is just not good enough.
Calculating Total Plumbing Fixtures needed
Mon, Feb 3, 2014 at 9:39:13 AM
Invert elevation tag for plumbing fixtures
Wed, Aug 17, 2011 at 11:21:32 PM
plumbing fixtures in foundation
Wed, Mar 22, 2006 at 10:11:18 PM
Plumbing Schedule Totals
Thu, Jan 30, 2014 at 1:05:02 PM
Plumbing Fixture Schedule
Thu, Jan 30, 2014 at 10:36:00 AM
Page generation time: 3.9226
