43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedules - Linking Numbers to a Drop Down List
Tue, Jul 29, 2008 at 8:09:42 PM | Schedules - Linking Numbers to a Drop Down List
MathewH101
Ok I've tried the search and its probably in here somewhere but I'm not quite sure what to look for.
 Basically I'm using MEP'09 and I want to set up a schedule that links a couple of parameters.
For example,
Room Type (text) Required Lighting Level (Number - lx) Maximum Lamp Power Density (Number - W/m2)
Plant Room                         250lx                                            8.00W/m2
So in a schedule which Revit calculates actual lighting level and actual power density for a room I could select Room Type from a drop down list, it would fill in the 2 columns (as above RLL/MLPD) and I could run a calculation to say +/-
Hope this makes sense, any help greatly appreciated!!
Room Numbers in Schedules
Wed, Jan 25, 2006 at 3:26:57 PM
Drop Down List in Family
Mon, Mar 19, 2018 at 4:12:19 PM
Electrical Panel Schedules - Space numbers
Wed, Sep 3, 2014 at 2:49:41 PM
DETAIL ITEM LIST NOT SHOW FULL LIST (2017)
Fri, Nov 18, 2016 at 10:40:32 AM
Drawings List Sheet Ordering
Thu, Feb 8, 2007 at 1:01:52 PM
Page generation time: 1.5815
