56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Archiving Revit for Drawing issue.
Tue, Jul 29, 2008 at 2:46:53 PM | Archiving Revit for Drawing issue.
Revitnut
Hello,I am using Revit 2009 Architecture within a large practice and one thing that seems to have eluded us all is whether Revit can perform an automatic archiving routine for drawings. By using scripting techniques in AutoCAD we were able by simply typing "archive" of setting of a process that would create a Bound DWG, DWF and PDF of a current drawing. This would be copied to a specific folder and made read only for archiving purposes and for issuing to consultants.The method of creating these three dwg types in Revit 2009 at the moment is long winded and time consuming. I would appreciate all comments.Many Thanks in advance.Revit Nut
Wed, Aug 13, 2008 at 11:15:55 AM | Archiving Revit for Drawing issue.
cganiere
cganiere Avatar
Every time you save Revit makes a copy of the entire project with a 000# at the end of the file name. I simply move it to another directory for a complete back-up. Usually I change the name to reflect the submittal date.
OR you could plot all your sheets to PDF or DWF.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Wed, Aug 13, 2008 at 11:20:50 AM | Archiving Revit for Drawing issue.
We place a copy of the central file in an archive folder at the completion of the phase and we mark it/ name it accordingly.  That takes care of all the drawings.  We also make a single combined PDF of all the drawings and that gives us a single source, quick viewing, visual record.  Two files and you have everything you need.
Wed, Aug 13, 2008 at 11:44:42 AM | Archiving Revit for Drawing issue.
tim123
4 Stars: 19 Votes
If you need DWGs, Revit will save them all as bound DWGs in one operation.
Archiving Projects
Wed, Jan 9, 2008 at 1:25:45 PM
Archiving Projects
Mon, Oct 3, 2011 at 11:59:15 AM
how to reduce size of file for archiving
Tue, Oct 24, 2006 at 2:35:52 PM
Drawing Issue Record
Wed, Sep 6, 2017 at 8:52:10 PM
Archiving Projects
Thu, Feb 14, 2008 at 8:27:51 AM
Page generation time: 2.2449
