53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railings floating above the ramp?
Tue, Jul 29, 2008 at 2:21:25 PM | Railings floating above the ramp?
CrystalNanney
I have a curving meandering ramp, with handrails that were a little buggy (jumped levels here and there) but now they seem to be following their host OK.  Except:  In places, the handrail's balusters float a little above or a little below the ramp, almost as if they're following a slightly different slope.  I am using Revit Architecture 2009.  Has anyone had this problem?
 The ramp is built from a series of arcs.  I'd have liked to use a spline but apparently there is no option for this (arcs and lines only).  The ramp's slope is flattening out to level at each point where the arcs connect; this appears to be causing the difference in slope between the ramp and the handrails.  Is there a way to fix this?
Thanks for any advice you can give,
Crystal
Edited on: Tue, Jul 29, 2008 at 3:40:00 PM
Wed, Aug 13, 2008 at 11:02:34 AM | Railings floating above the ramp?
cganiere
cganiere Avatar
Have you tried splitting the railing into more segments?
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Trying to make a non ADA ramp but always have problems with railings, need help!
Wed, Oct 16, 2013 at 9:10:44 AM
Flat Railing with a ramp as a host
Mon, Dec 27, 2010 at 6:27:12 PM
Railings on a curbed ramp
Thu, Mar 17, 2005 at 2:50:58 PM
railings have mind of their own
Tue, Nov 25, 2008 at 10:50:01 AM
Floating Staircases
Fri, Oct 31, 2014 at 1:09:23 PM
Page generation time: 0.3354
