70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> autoCAD Survey Plans to 3D Topo
Tue, Jul 29, 2008 at 12:48:52 AM | autoCAD Survey Plans to 3D Topo
CavCORP
when doing a Topo with an imported survey plan from autoCAD does it have to be in AHD levels? i do a query on the contour line and they are just lines not points or anything like i have worked with in the past. can someone advise me on what the surveyor needs to do for me
Tue, Jul 29, 2008 at 3:41:10 AM | autoCAD Survey Plans to 3D Topo
4 Stars: 203 Votes
Hi CAV, when you import a 3d topo with contour lines you must import in "SITE" plan, th contour lines in CAD must have the right elevation, so after import the DWG to Revit, go to toposurface menu and convert you countours to points of revit...
Thu, Jul 31, 2008 at 5:33:18 PM | autoCAD Survey Plans to 3D Topo
CavCORP
thanx typhoon,
i knew i had to do it in "SITE" plan, but even when i open the contour survey up in autoCAD and do a 3d orbit on it it shows that they dont have the proper slope and they arent at the proper levels. is it how the surveyor has to format it or what?? not sure because i have always had the right levels at my old job but here they dont because this is the first time they have needed it to be 3D...
Fri, Aug 1, 2008 at 4:12:58 AM | autoCAD Survey Plans to 3D Topo
4 Stars: 203 Votes
When you open in CAD the file, you must "List" the contour line and check if the "Z" have the right elevation, if not, my advise is do it in CAD because if you import the contours to Revit with Z=0 then you must "put" the points in the contours one by one, it's sucks....
topo survey AutoCAD to Revit
Thu, Feb 26, 2009 at 11:45:41 AM
importing topos for a Site Plan
Sat, May 28, 2005 at 10:20:13 PM
Change of Infornation on a Call out Ref and Easting/Northings on a Topo survey
Thu, Feb 21, 2013 at 12:37:10 PM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
Importing AutoCAD topo 3D lines
Wed, May 25, 2005 at 3:33:44 AM
Page generation time: 0.9234
