58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> wall clean-up
Mon, Jul 28, 2008 at 1:28:01 PM | wall clean-up
bert
Hi All!
We're currently trying to model one of our previous projects, with some succes. Here's our current issue: we have an exterior CMU wall with stucco, with the occasional Stud wall bump out. Inside the stud wall, however, we're still seeing stucco from the CMU wall (see image). We first tried using a single wall with wrapping, then opted for three walls in a U-shape, both with the same result.
We were thinking we could use a third wall type (CMU without stucco) to be placed where the stud bump-out would occur. Is this the preferred technique or are we missing something else?
Thanks for reading!!
(we're using Revit Architecture 2009)
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Mon, Jul 28, 2008 at 2:26:59 PM | wall clean-up
If this does not occur in too many place, just use your edit cut profile in plan.
Mon, Jul 28, 2008 at 6:51:19 PM | wall clean-up
bert
Thanks WWHub,
It actually does occur in quite a few places, and it might be easier to use a third CMU wall without any finishes. I've experimented with both, and it seems to be the quicker option.
Thanks for your help.
using RAC-2013
Tue, Jul 29, 2008 at 10:38:27 AM | wall clean-up
LIZARD2806
3.5 Stars: 7 Votes
bert,
I had the same situation and did exactly what you are doing.  This is very easy if they were solid pilasters, but the program is just "doing it's job" in this case.
WWHub has the right idea were it only to happen in a couple places, though as that extra wall has the potential for creating issues down the line.
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:25 AM
Wall clean-up
Fri, Nov 21, 2008 at 3:21:13 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:49 AM
11
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:10 AM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:20 PM
Page generation time: 2.0369
