65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> new wall type creation isn't unique?
Sun, Jul 27, 2008 at 4:32:51 PM | new wall type creation isn't unique?
ICON1962
trying to create new wall type with green tile instead of red,
i duplicated the red tiled wall
renamed it to green tile wall
changed appearance of finish of the red tile component to green
 result was both walls now show green tile, intent was to keep the original tile color as red with the new wall showing green
what step did I miss?
Sun, Jul 27, 2008 at 9:35:38 PM | new wall type creation isn't unique?
ICON1962
THE TWO WALLS SHOWN ARE THE SAME WALLS FROM PREVIOUS ATTCHMNT.
WHY IS IT THAT WHEN I CHANGE THE THICKNESS OF ONE WALL IT CHANGES ONLY THE WALL THAT WAS SELECTED BUT, WHEN I CHANGE THE COLOR OF THE CERAMIC TILE (ALSO IN THE "EDIT ASSEMBLY" DIALOGUE BOX) IT NOT ONLY CHANGES THE COLOR OF THE TILE IN THE SELECTED WALL BUT, ALSO THE WALL THAT WAS NOT SELECTED FOR EDIT.
Sun, Jul 27, 2008 at 9:51:46 PM | new wall type creation isn't unique?
ICON1962
found the following posting, thank you
User Menusdbrown
Joined Fri, Dec 12, 2003164 Posts5 Stars from 1 Votes
YOu need to change the material assignments in each wall type to be diff. from each other.
Wall Type creation via API -H-E-L-P.
Tue, Jun 10, 2008 at 10:01:53 AM
Making your first wall type assembly
Wed, Apr 26, 2006 at 3:51:42 PM
Wall tags don't show type mark
Thu, Jun 22, 2006 at 12:29:47 PM
"Revit Help Image" Wall Creation
Thu, Jan 15, 2009 at 1:28:25 AM
editable chart
Thu, May 2, 2013 at 7:43:00 AM
Page generation time: 2.2782
