85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> View port titles I want a box around the name as well as the drawing number
Thu, Jul 24, 2008 at 3:17:10 PM | View port titles I want a box around the name as well as the drawing number
aaronkennedy
2009 version
 Does anyone know how to make a viewport title with boxes around both the drawing number / sheet # AND the title of the drawing?  The box would need to flex to fit the words?
Any advice
 Thanks  AAron
Thu, Jul 24, 2008 at 4:25:03 PM | View port titles I want a box around the name as well as the drawing number
Did it flex in CAD?  No?  I guess you did something else if that is your standard.  Same thing here.
Thu, Jul 24, 2008 at 4:54:44 PM | View port titles I want a box around the name as well as the drawing number
aaronkennedy
Our title in CAD did / does flex.  Is there a way to grab it and use it in revit?
Fri, Jul 25, 2008 at 5:59:45 AM | View port titles I want a box around the name as well as the drawing number
Did you try?  You can create your own view title and with a parameter you too can flex a line ofr box in it but just like in CAD, it will not flex automatically to the length of the text.
Fri, Jul 25, 2008 at 11:35:36 AM | View port titles I want a box around the name as well as the drawing number
aaronkennedy
The CAD flexs automatically in CAD,  I have not been able to pull it into Revit yet.  I will make the one and just flex it each time.  Thank you.
AAron
Fri, Jul 25, 2008 at 4:29:05 PM | View port titles I want a box around the name as well as the drawing number
TABEST
4 Stars: 4 Votes
you can't flex it graphically, it has to be numerically (feel free to correct me if wrong, but I never managed to figure out a method).  You would have to tell the view title element that it is to draw it's box(s) a certain size... the issue is that the viewport object contains the view title element, and thus there is no way to tell the object that it is a certain size...  our company has found that if you need a box as I think you are using it, just use detail lines and draw your box.
Sat, Jul 26, 2008 at 8:01:11 AM | View port titles I want a box around the name as well as the drawing number
You are right TABEST ... since reference planes are not available in a viw title family, you can not make the box visually adjustable.  You would have to set up a few fixed ... type families or an instance based family where you would enter the number.
It's been awhile so I may be wrong but I don't think autocad reads the visual length of a text field so I don't know how the AutoCAD title would be automatic.  but then again ... my memory is getting worse.
Mon, Jul 28, 2008 at 3:51:40 PM | View port titles I want a box around the name as well as the drawing number
aaronkennedy
Thank you TABEST.  WWhub, I can try to send you the self adjusting title block in CAD 09 if you would like.
View port titles
Tue, Apr 24, 2007 at 2:18:56 PM
Legend Drawing Titles
Mon, Sep 24, 2007 at 6:45:32 PM
View Titles
Thu, Jul 13, 2006 at 2:58:51 PM
MULTIPLE VIEW TITLES
Thu, Jan 31, 2013 at 5:46:52 AM
VIEW TITLES
Mon, Jun 18, 2018 at 10:24:53 AM
Page generation time: 2.6755
