137 Users Online (136 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> "paint" pattern id?
Thu, Jul 24, 2008 at 11:50:23 AM | "paint" pattern id?
rquist
after you "paint" a surface is there a properties dialogue somewhere that identifies the specific paint fill that was used?
is there a way to "match properties" that would allow only the "paint" pattern and not any other properties to be copied to the item to be modified?
Thu, Jul 24, 2008 at 1:14:43 PM | "paint" pattern id?
rkitect
rkitect Avatar
4 Stars: 29 Votes
A couple of ways to track painted surfaces that I've found:
1) Use a material tag.
2) Using the paint bucket, hover over the painted surface, the status bar should tell you what is currently "painted" on the surface.
To my knowledge, the only way to change the paint pattern (I'm assuming you mean the material, not just the fill pattern) with no other properties is by using the paint bucket.
paint fill pattern complete image reference
Fri, Jul 18, 2008 at 3:55:55 PM
"wavy" fluting pattern on wall surface
Fri, Jul 13, 2018 at 1:09:54 PM
"Fishscale" Shingle surface pattern
Tue, Feb 16, 2010 at 11:22:29 PM
Brickwork Render
Mon, May 10, 2010 at 4:04:28 AM
White ceiling paint (and other white objects) Rendering "GREY"
Wed, Sep 27, 2006 at 11:52:48 PM
Page generation time: 2.0796
