45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> 2009 ROOM BOUNDING - non enclosed errors
Recently, upgraded to Revit 2009. Started to place ceilings into the project and began to have room bounding issues. Suddenly, half the rooms that had ceilings added now display as a non enclosed regions. Checked all my setting- and can't figure out whats causing this...is there a bug in the new room bounding features? I notice I now have a room bounding check box for ceilings and floors - these are on. Also, it seems intermittent- same ceiling system works in one room and and not in another. p.s. all these rooms were bounded and tagged in 2008 before the upgrade- this started to happen with the placement of ceilings. Thanks
Hy, i think the problem is because you are tagged the rooms in 2008, try to delete one tag room (area, and so one) and put a new tag room in 2009 and check if the problem continue in that room... When we open in 2009 a file from 2008 he don't recognise many things, materials, plantings, Rpc's, etc...
Solved this problem by going to the room and area settings and unchecking "area and volume" calculation - just calculate area only. All my tags and boundaries came back. Somethings up with the volume calc. Another bug in 2009- the expanded template settings now let you set linked files- unfortunatley, this makes Revit crash. Tried it on 4 different computers in my office- crashed every time. wish this worked because I'm doing a 500,000 sq ft project divided into 4 files and linked together,
room is not in a properly enclosed region |
Wed, Aug 27, 2014 at 4:08:02 PM
Rooms errors |
Fri, Oct 9, 2015 at 1:08:44 PM
room bounding problem |
Fri, Jul 28, 2017 at 4:03:50 AM
13
room bounding parameter in wall |
Fri, Jun 27, 2008 at 10:17:07 AM
Ceiling not bounding room |
Wed, Oct 6, 2010 at 4:01:35 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
