113 Users Online (112 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exporting the Groups to ACAD as Blocks
Wed, Jul 23, 2008 at 2:36:08 PM | Exporting the Groups to ACAD as Blocks
Devrimeksi
Is there any way of exporting groups created in Revit to a CAD format with all the group properties?I found this problem when I created a unit type group and copied multiple times in different floor levels. When Converting this to a CAD format, the groups don't come as groups. So if the engineer or other architect from another company wants to make a change in the unit type, they have to do it one by one in every level.Is there any way of solving this issue?Any help would be greatly appreciated.Thanks!
Wed, Jul 23, 2008 at 2:51:48 PM | Exporting the Groups to ACAD as Blocks
4 Stars: 201 Votes
Hi, the "Groups" in Revit it's like a "Block" in Cad, so you can create a group in revit, save group and then export to cad...
Wed, Jul 23, 2008 at 3:24:26 PM | Exporting the Groups to ACAD as Blocks
Devrimeksi
thanks for the response, this answers some portion of our problem.
We are trying to figure out a way to export the overall floor plan or elevation to CAD with the groups attached as Blocks so that the cad file would have all the groups as Blocks (or XREFs) which makes editing so much easier.
For now all when we export the floor plan to CAD all the groups turns to single lines. The result is editing all the units (or bay windows or etc.) one by one. It would be much easier to edit them if they the groups would become Blocks in the drawing.
Wed, Jul 23, 2008 at 3:56:34 PM | Exporting the Groups to ACAD as Blocks
3.5 Stars: 395 Votes
Groups will not export as ACAD blocks.
Tue, Mar 19, 2019 at 2:45:52 AM | Exporting the Groups to ACAD as Blocks
Sylar46
Create the block in AutoCAD, import the dwg file into Revit, group the the dwg block instance in Revit.
Exporting the groups back to AutoCAD will explode the Revit groups but still keep the AutoCAD block instances.
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:46 AM
Exporting Revit Drawings to ACAD
Wed, Nov 10, 2004 at 11:49:36 AM
Exporting Linked Revit Files coming in as Blocks
Fri, Sep 2, 2011 at 10:16:38 AM
dimensions missing after exporting to ACAD
Mon, Jan 5, 2009 at 3:18:52 PM
exporting revit to cad issue- duct and pipe fittings converted as blocks
Wed, Jun 17, 2015 at 1:58:55 PM
Page generation time: 5.7527
