41 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> HVAC Diffuser will not print
Wed, Jul 23, 2008 at 11:51:06 AM | HVAC Diffuser will not print
psemrau
I have currently inserted a HVAC Diffuser, the family  I don't think it was modeled properly, since it is made only with model lines.
It shows perfectly in the view, but when you print, they are not showing, even in PDF, previews anything...
Has anyone had that same problem?
Thanks
Wed, Jul 23, 2008 at 12:25:16 PM | HVAC Diffuser will not print
broncos4life
3.5 Stars: 11 Votes
When you print that sheet or what ever you are printing that shows that HVAC diffuser, use the raster processing option n of vector processing.
HTH
Edited on: Wed, Jul 23, 2008 at 12:25:29 PM
Wed, Jul 23, 2008 at 12:40:35 PM | HVAC Diffuser will not print
psemrau
WOW! Thanks!
It fixed it, but here is another question.  Are there any drawbacks to the raster processing as opposed to the vector? things like processing time? or image quality?
Wed, Jul 23, 2008 at 12:48:13 PM | HVAC Diffuser will not print
broncos4life
3.5 Stars: 11 Votes
Yes, rastering takes more time to pring than does vector.  Other than time, there is no drawback, so I wouldn't use raster unless you have to get things to show, as in this case.
HVAC diffuser question
Thu, May 17, 2012 at 9:16:15 AM
2D diffuser transparency
Wed, Jan 8, 2014 at 8:31:37 AM
12
Linear Air Diffuser
Sat, Jun 11, 2016 at 12:58:54 AM
Diffuser
Tue, May 29, 2012 at 8:24:47 PM
REVIT MEP, Diffuser Airlfow Parameter isssue
Mon, Jun 21, 2010 at 1:46:23 PM
Page generation time: 1.0716
