85 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Tips & Tricks >> Lines in 3D views...picture attached
Tue, Jul 22, 2008 at 2:46:01 PM | Lines in 3D views...picture attached
tinninttu
I am in 3D perspective view and am set in the view with "shading with edges" but it views as a combination of shading with edges and hidden lines. You can see both at the same time. I want shading with edges, so how do I get rid of the hidden lines? Is my file corrupt or is it fixable?  Thanks
stephanie
Tue, Jul 22, 2008 at 2:53:59 PM | Lines in 3D views...picture attached
4 Stars: 203 Votes
Hi there, in the "Project Browser" pick once in 3D and delete them, go to a plan view and in the top menu, pick in the "House 3D", it generate another 3D view, pick in "shading with edges" and see if it solve  the problem...
Wed, Jul 30, 2008 at 10:02:40 AM | Lines in 3D views...picture attached
tinninttu
Could you be a little bit more clear. I am understanding what you're saying, but I'mnot following your steps in revit. Thanks for your post, but if anyone else has anything to add, please do. It's starting to get very frustrating!!!
Wed, Jul 30, 2008 at 10:59:27 AM | Lines in 3D views...picture attached
aaronkennedy
Tinnintuu
What he is saying is just delete the 3-d view.  You can do it from your project browser, the menu with all the views listed, floor plans, ceiling plans, sheets, so on.  Just right click and delete the view.  Then in the menu bar at the top just click on the default 3d view and it will make a new 3d view.  Sometimes I have to do this several times a day but lately I have not had to do it for a week..
 I am not sure why the problem occures.  If you have a view you want to keep for a rendering or perspective just duplicate the view then once you get it where you want it just do not mess with it any more
Wed, Jul 30, 2008 at 11:05:11 AM | Lines in 3D views...picture attached
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I read from autodesk that when this happens, supposedly.... that if you do the following it will reset the 3D View:
view/orient/top
Wed, Jul 30, 2008 at 11:26:39 AM | Lines in 3D views...picture attached
tinninttu
Thanks, I'll try that. I'll post again if it doesn't work. Thank you again.
Lines everywhere in 3d (picture attached)
Mon, Oct 20, 2014 at 9:52:37 PM
New material - my attached picture disappear
Sat, Jan 30, 2010 at 4:22:53 PM
Revit topology display in cut and elevation views
Thu, Dec 12, 2019 at 4:42:26 AM
Topography breaks 3D camera views
Thu, Sep 14, 2017 at 7:44:11 AM
Lines color legend
Tue, Dec 24, 2013 at 9:36:25 AM
Page generation time: 1.0152
