Forums >> Revit Systems >> Technical Support >> Revit MEP 2009 - Rooms, Spaces, etc...
2 Posts No Rating |
Hello, we just upgraded to MEP2009. The architectural model we are using as linked files has rooms set up. We would like to get the room information in to MEP2009 as well but can't get it. Clicked already in the element properties of the linked architectural file the box for "room-bounding" but without major success. The room schedule in MEP does not provide any room information. We tried a couple of things yet but then error messages with "can't create space", "mulitple space..." etc comes up. Does anybody has a good guide how to get the information from the architects into the MEP model? In 2008 you had the option of copy/monitor rooms but with the changes to space, this doesn't exist anymore. Thanks Vokay
2 Posts No Rating |
I too am haveing this same trouble with MEP. I thought that with the upgrade it would have corrected this problem. Anyone out that that can help us with this. Would be a great help.
3 Posts No Rating |
Didn't provide copy/monitor for Room Name in Revit MEP 2009. You can check with Attached file to overcome this problem. Now I start using Revit MEP. But I can't find completed smaple MEP file for reference. Do you guy have any sample project for reference like MEP poject?
3 Posts No Rating |
I too was looking for the copy/monitor rooms and was lost. The video link posted is 100% exactly what I needed. Thanks
where can i find the previous video the narrator of that video link said they just covered? like how do i get architectural model rooms into my mep 2009 file to do IES calcs? thanks
Rooms and Spaces from linked model (Revit MEP 2011) |
Sun, Jul 18, 2010 at 9:40:07 AM
Programming spaces/rooms in Revit |
Fri, Jun 21, 2013 at 9:20:35 AM
MEP + Unoccupied Space?? |
Fri, Feb 19, 2010 at 2:53:15 AM
Revit Spaces Elec VS Mech |
Tue, Feb 2, 2010 at 10:50:51 AM
Load analysis problem in MEP 2009 |
Wed, Jun 25, 2008 at 11:45:47 AM
Members: | 2115259 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
