37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Making a
Mon, Jul 21, 2008 at 11:57:30 PM | Making a new schedule with feilds listed down the column
ny22
Hello,
I am currently working on a large residential project with over 50 doors, most are varying in some way. Aswell as over 150 windows again varying in many ways.
I have been using the schedules existing in revit, which as a schedule does, creates long lists of text. As an architect and thinking of the builders too, we work visually and want to see the object/elevation at the same time - not having to flick to other pages for the visual element.
In previous projects at other firms it is agreed in the office that the door/window information is written directly below the elevation which in turn displays all the visual components.
Therefore being new to revit, My question is can I create a family or similar tool which will be live and display the same information that appears in the schedule, individually for each door/window that can be placed directly below the elevation?
Any help would be good, Thanks in advance.
Edited on: Tue, Jul 22, 2008 at 4:44:43 AM
Tue, Jul 22, 2008 at 12:05:40 AM | Making a window schedule
ny22
I just had a thought that one way to accomplish the above would be if I could create individual schedules for each door/window and format the feilds down the page instead of across the top?? is this possible, I had a play in the edit schedule properties but could not quite get there.
Tue, Jul 22, 2008 at 6:48:21 AM | Making curse
3.5 Stars: 400 Votes
You could create a "tag" that reads the same information that a door schedule would read.
Tue, Jul 22, 2008 at 7:14:17 PM | Making curse
ny22
That is agood idea, Im quite new and will have to go thru the tuts do make tags. but if the door already has a tag which is linked live between the schedule and tag, Will making a new tag for the information interfer with the existing tag displaying on the door?
Wed, Jul 23, 2008 at 5:39:08 AM | Making curse
No, you can have multiple tags.
Questions like this are easily discovered on your own.  Simple put two room tags in the same room - one with the name only and one with the name and area.....
Books on making revit familys
Thu, Feb 23, 2006 at 10:06:57 PM
Making beam family bad constraints.
Wed, May 22, 2013 at 9:07:00 PM
Companies making thier own families...
Thu, Jun 11, 2009 at 8:48:53 AM
Massing - making a 'noodle' shape
Mon, Apr 23, 2012 at 6:11:01 PM
Making underground area for parking
Fri, May 9, 2008 at 7:20:06 AM
Page generation time: 0.3518
