67 Users Online (66 Members):
Forums >> Community >> The Studio >> Toposurface&subregion problems
1 Posts No Rating |
I'm experiencing this strange situation: seems subregions "cut" toposurfaces! As you can see on the attached images, the level of the plan cut a toposurface on a certain height. Now, toposurface used is made by a material with a solid fill pattern when cut and in fact we see where toposurface is cut. I added a subregion to the toposurface and as a result now I see the projection blank of the subregion as we see on second image.
I get the same result even with pads...
Am I missing something?
Thanks in advance.
33 Posts No Rating |
Im using Revit 2008 and still have the same problem, phasing pads will not work because they cut out the topo in the wrong phase. Revit has not provided BIM
10 Posts No Rating |
Has anyone got a solution to this problem with subregions. We are having problems with sub regions in toposurfaces.When we create a sub region revit changes the contours erratically.....This also happens if we try to split the surfaces.
29 Posts No Rating |
I'm having the same problem. When i create a subregion, the contours of the toposurface change. Has anyone found a solution yet? ps i'm using revit architecture 2009
I don't think so, i hope in 2010 they did solve the issue....
Workaround - duplicate your toposurface, place the new copy in the next phase, and modify it accordingly. Haven't used topo's except as exploratory, but that is what I figured out had to be done to achieve what I think you want.
Thanks for the answers. I guess i'll just have to wait and see if it's fixed in the next revit. Tabest: I already have 2 topo's, one for each fase. Each topo has subregions and they seem to distort the contour lines in the same pattern.
Edited on: Thu, Apr 16, 2009 at 1:47:33 AM
Adding a subregion to a second toposurface |
Thu, Apr 18, 2013 at 3:01:18 PM
Property Lines and Toposurface Subregion Lines overlap |
Wed, Dec 1, 2010 at 12:12:03 PM
Toposurface subregion problem |
Sun, Nov 18, 2007 at 4:23:28 PM
subregion road in toposurface |
Fri, Feb 22, 2013 at 8:26:36 AM
Tag for Subregion of Toposurface |
Sun, Jun 28, 2009 at 1:52:44 PM
Members: | 2056126 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
