90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Generic model family
Sun, Jul 20, 2008 at 2:52:06 AM | Generic model family
akome555
Hi,
How do I create a generic model in place family with family type.
Also, the model i created  is not seen on plan with the right visibility. It is a new cornice model created in Revit 2009. while in revit 2008, it can be seen correctly.
Sun, Jul 20, 2008 at 4:53:26 AM | Generic model family
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, in-place families are used for creating one instance of geometry. Because there arent different sizes (width, length, depth etc) within your generic model, they dont have a type. Type refers to the specific attributes of one of the family elements ie Family: Window; Type: 1900x1800mm, 600x1500mm. You'll notice in the type selector various components of the one family, each with varying properties.
I read this info in "Marathon Drafting", so I cant take credit for it.
Rules for In-Place families.
  • Anything that is a specific, one of a kind condition.
  • In-place families are NOT for multiple instances.
  • Are NOT for tagging or scheduling… though it can be done.
  • I use them for reveals, sweeps, walls, openings that are otherwise difficult.  Concrete tilt up const. lends itself to a number of in-place families.
  • Use your 3D view!!  Much quicker..
  • Apply material specs intelligently.  Do not just assign arbitrary materials as you WILL have to come back and change it otherwise.
  • Dissasociate work plane to avoid future errors..
Rules for External families
  • External families ARE for multiple instances
  • Build a good library!  Time spent building intelligent families is much more time spent later.
  • Use these for generic conditions or often-used specific conditions.
  • Search online first for a family that at least closely resembles what you want before you spend alot of time building your own.  Often editing somebody else’s work is much easier.
  • Keep in mind your scheduling, and rendering needs down the road. PLAN AHEAD!
In regards to what it look likes, it seems as though you have an underlay on. Go to view properties and you should see underlay, and check to see it is set to none.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Sun, Jul 20, 2008 at 5:19:10 AM | Generic model family
akome555
Thanks timbo89,
Got it.
Generic Model Family
Fri, Apr 4, 2014 at 10:38:37 AM
generic model family not cutting in section
Tue, Jan 11, 2011 at 7:14:50 AM
Generic Model Materials
Wed, May 18, 2005 at 5:03:38 PM
CREATING A SCHEDULE FROM A GENERIC MODEL FAMILY?
Mon, May 11, 2009 at 11:49:38 PM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
Page generation time: 2.7391
