33 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> material library incomplete
95 Posts No Rating |
Hi all. Thanks for taking the time to read this: I've been working on my firms standards file, and started from a blank file to make sure I was in full control over everything. This has been working out just fine, untill now. I'm trying to create walls, and noticed that the material library is my template file is far smaller then in a regular default template file (see image). Can somebody tell me how I can load all of these into my own template file as well?? Thanks!!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer |
image seems to be missing...
using RAC-2013
Hi, open your ORIGINAL template file (*.rte), then open your STANDARD template file (*.rte), go to File-Transfer Project Standards, check all and OK, save the STANDARD.rte, i think this solve the problem...
Thanks Typhoon! That totally did. I'm sure I'll need this tool for a few other things as well. ![Smile](/images/smiles/smile.gif)
using RAC-2013
You Welcome...
Question about shared custom material library |
Wed, May 18, 2016 at 6:44:31 AM
How do you add an imported material to Revit's material library ? |
Mon, Aug 16, 2010 at 8:06:17 AM
Material library |
Fri, Mar 3, 2006 at 9:11:37 AM
Material Photo's Library |
Tue, Dec 8, 2009 at 3:19:26 PM
Help me! Lack of BMCD2AR3 material library in revit building 8. |
Sat, Oct 8, 2005 at 9:54:16 PM
Members: | 2017910 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
