111 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> floor plan view not available for underlay
160 Posts No Rating |
I have a "first floor - new construction" floor plan view that I can pull onto a drawing sheet but, it does not show up in the available underlay views. It's time to draw the foundation and I want to "trace" the first floor. Seems like I should know this one.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
You can only bring in Levels as underlays, not individual views. This is because you have views that can be totally unrelated to the model (ie: drafting views). To prevent coordination issues, they make it so that you have to bring in everything that is visible on the level. The visibility should be the same for the level you bring in as the view you are working in (so if you have walls turned off in your view, the walls will be off in the underlay as well).
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Underlay.... problems |
Tue, Jul 31, 2007 at 11:36:03 PM
Second Floor Plan w/ First Floor Underlay |
Mon, Jun 19, 2006 at 12:10:25 PM
REVIT 2015 - Underlay: EXPORT? |
Tue, Aug 5, 2014 at 2:54:54 PM
Underlay in Site Plan |
Fri, Aug 6, 2010 at 8:26:01 AM
underlay |
Mon, Aug 11, 2008 at 6:18:01 PM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
