104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Issue date vs Revisions
Fri, Jul 18, 2008 at 1:42:43 PM | Issue date vs Revisions
reqork
I'm trying to get our issue date/revision schedule on our sheets to show the issue date (compared to a revision) without having to draw a cloud to get that issue date to show up. I know a workaround is to just draw a small cloud somewhere and shut it off in the schedule so the issue date shows up, but I'm hoping there is a better way of doing this. Is it possible to get  this to show without having to cloud?
(using Revit Arch 09)
Thu, Jul 24, 2008 at 1:32:27 PM | Issue date vs Revisions
reqork
the lack of response makes me believe this is a dead end alley.
Mon, Aug 4, 2008 at 7:01:46 PM | Issue date vs Revisions
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, I may be misunderstanding you, but in the project browser under sheets, right click on a sheet and scroll down to properties. A dialog box should pop up, scroll down and you should see "Revisions on Sheet" and edit next to it. Click edit, and tick the boxes. Is that what you want?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Aug 5, 2008 at 6:15:58 AM | Issue date vs Revisions
3.5 Stars: 395 Votes
You can create a shared parameter for your sheets that is instance based and use that.
Tue, Oct 14, 2008 at 10:10:36 AM | Issue date vs Revisions
dfitzladdy
5 Stars: 3 Votes
timbo89's response helped me with this same issue.  First I went into Settings > Revisions, and created a revisions that said, "date isssued" with the date, but under "numbering" told it "none".  This way, subsequent revisions start with 1, and the "date issued" is still the first item on the list, but does not have a number in the revisions list on the title block.  Then, for every sheet i have, I did what timbo89 said and checked the "date issued" revision to show up, without having to draw a cloud on each sheet and hide it.
Titleblock Date Issue
Tue, Jan 15, 2013 at 10:41:19 AM
Why is my revisions sorting by date and not sequence?
Thu, Aug 13, 2015 at 12:11:53 PM
revisions display issue [ 1 2 ]
Mon, Sep 15, 2014 at 3:23:27 PM
15
Revit 2013, Issue Date Question
Thu, May 2, 2013 at 4:16:13 PM
"Sheet Issue Date" - Bug
Mon, Jun 6, 2011 at 12:06:58 PM
Page generation time: 0.9604
