28 Users Online (27 Members):
Forums >> General Discussion >> Wishlist >> Select only required elements
3 Posts No Rating |
hi everyone, as am learning revit i came across this doubt (comparing with AutoCAD) 1. is there way to select elements which were selected previously 2. suppose i select a set of elements and want to de-select just one of it, i dont have an option other than coming up again as done before. is there a way to solve these or does it remail as a wish list item.. Any suggestions, truely appreciated. Thanks in advance
![4 Stars: 5 Votes](/images/stars_4.gif) |
Hey, If you select a group of elements and a certain element was accidently selected or is'nt needed, then just hold down shift and select the element that you dont want in the group. This will de-select the item.
Edited on: Thu, Jul 17, 2008 at 1:59:22 PM
If you want to select previously selected elements .... before you do anything else right click and you should have a select previous option.
select elements on current level only - revit 2014 |
Tue, Jul 23, 2013 at 7:52:33 AM
I can not select some elements in a file |
Wed, Apr 10, 2013 at 5:28:15 PM
Given a central model: unable to select some elements |
Tue, Apr 16, 2013 at 12:55:06 PM
Can't select elements like in 2011 |
Wed, Jun 22, 2011 at 8:19:09 AM
work plane |
Fri, Jun 28, 2013 at 9:12:11 AM
Members: | 2018010 | Objects: | 22948 | Forum Posts: | 152219 | Job Listings: | 3 |
