Forums >> Revit Building >> Technical Support >> handrail balusters don't show up on stairs
160 Posts No Rating |
I created a rail system that looks great for the deck I'm working on. The balusters show up on the deck platform but, don't show up on the stairs. Anyone have a suggestion why the balusters don't show up on the stairs??
Can you put some screenshots to figure out?
I made the deck railing with no posts and added those in separate. I have to figure out how to create a new post profile. I figured out how to make a new rail profile but, it doesn't seem to work the same way for posts. Anyway, I probably won't use the same railing design for the stairs but, thought I should figure this out. After I made the stairs which came in with a default rail, I matched properties to change the default rail to the one on the deck
Hi, you must pick on the rails of the stairs and check if they are equal (name) of the rails of the deck, also you can delete the rails of stairs and add a new one using the same kind of the deck...
Handrail without Balusters |
Wed, Oct 2, 2019 at 4:04:39 PM
Handrail Supports on Multistory Stairs |
Tue, Jun 24, 2014 at 3:10:16 PM
Handrail - Wall mounted |
Fri, Apr 28, 2017 at 5:35:54 PM
handrail |
Thu, Jun 16, 2011 at 8:34:08 PM
Balusters / Railing / Stairs - Custom? |
Thu, Nov 9, 2006 at 7:53:09 AM
Members: | 2105174 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
