52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Slabs drawn in Arch used in Structure?
Thu, Jul 17, 2008 at 8:29:00 AM | Slabs drawn in Arch used in Structure?
jdm5017
Hey all, I'm new to the world of Revit as is the firm I work for.
 One of the main things that we are struggling with is coordinating time schedules. We are able to link our Structure drawings into Arch with no problem and vice versa, but I was wondering if there's any way to have some elements be part of both and not merely linked.
 For instance, sometimes the architect will want to draw a slab to make sure all of his components are fitting correctly, and doesn't have time to coordinate with the structural department for us to go into our version, place the slab, and then reload it. So he draws the slab in there. The problem is that when we go into our structure copy there already is a slab in there, and we need to redraw one over it for our structural model. Then we have to tell him so he can go into his arch model and delete it.
 Is there a way that the slab he draws in Revit Arch can become the same slab we use in Revit Structure and more than just a mere linked element so it does not need to be drawn twice?
 Thanks in advance.
Thu, Jul 17, 2008 at 9:20:19 AM | Slabs drawn in Arch used in Structure?
rkitect
rkitect Avatar
4 Stars: 29 Votes
This is actually something I've struggled with as well here at our firm which does a lot of coordination between disciplines.  For most of our projects we decide to go with the slab in the structural model, mainly becuase most slabs are structural and the Structural Engineer needs to be able to run analysis or edit the structure of the slab assembly at any point of the project.  The issues here are many and include:
1) When the slab is part of the structural model, the Archtiect can not place floor hosted elements in the model, he must use face based models (which lack in the out-of-the-box family library).
2)The architect can not see the changes that the structural engineer has made until he receives the latest and greatest model meaning he doesn't know that he's going to have to move those 50 walls he just modeled to create that funky looking exterior wall facade becuase the slab had to grow by an inch to accomodate the correct structure. Smile
Probably one of the most effective ways to accomplish what you want is to have the architect copy/monitor the slabs into their model.  My understanding is that this will psuedo copy the slabs into their model, allowing them to make adjustments but not make the adjustment permanent.  Although i have never used this feature, I think it basically tells the Engineer "Hey, the architect wants to do this to the slab.  IS that ok?" and the decision on the change is up to you.
Now, the monitoring of these elements is only as recent as the file that they are copy/monitoring from.  So if you change something, the architect obviously won't see this change until you send him the updated file.  When the archtiect gets the file, all elements that you have modified will alert the architect to the changes so long as he has the copy/monitored.  So there is a complex level of coordination that is needed (for instance when you're working on slabs, let them know so they can copy/monitor all the slabs, or when you're working on columns, let them know so you can copy/monitor all the columns) for these notification to work.
To get a good idea of the function of the tool, search for Monitor in the Revit help file.
HTH, and best of luck!
Hello All! Moving Revit Arch Drawing to Revit Structure Problems
Thu, Feb 12, 2009 at 8:18:59 AM
Sloped slabs and spot elevations
Thu, Mar 6, 2008 at 1:18:13 PM
Structure visibility of multilayer elements such as walls and slabs.
Wed, Dec 18, 2013 at 8:34:23 AM
trying to mitre a horizontal wall drawn as an arch with a vertical wall
Mon, Oct 18, 2010 at 6:44:52 PM
Cannot see arch object when model is linked into revit structure from revit arch
Fri, Jan 22, 2010 at 9:58:53 AM
11
Page generation time: 0.5699
