140 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Heavy Weight Leader Arrows
Wed, Jul 16, 2008 at 8:43:20 PM | Heavy Weight Leader Arrows
Luckydug
3.5 Stars: 3 Votes
I know this ones been thrown out there before but is it possible to create a (non filled) custom leader arrow that has a heavier pen weight than the leader line.....and before KingRevit and WWHub reply with some condescending advice about 'trial and error' and 'help files'...yes I've given them a go and I've even read some other forums!
Wed, Jul 16, 2008 at 8:56:20 PM | Heavy Weight Leader Arrows
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Im pretty sure you can create your own custom arrow, but I dont think you can make its linewight thicker. Go to Settings-->Annotations-->Arrow heads and create your custom arrow. Im using RAC2009, but I dont know if this option is available in 2008. Hope this helps =)
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Wed, Jul 16, 2008 at 9:12:45 PM | Heavy Weight Leader Arrows
Luckydug
3.5 Stars: 3 Votes
Thanks for the reply Timbo.. I got that custom size and angle bit sorted..it is just the weight of the arrow head I was wanting to change to appear heavier thah the leader line...(the big wigs round ere are bugging me cause the revit arrow is not office standard..hohum)..the question seems to have been around for a while and the only answer I've found so far are 'NO' ....I just thought someone may have nutted it out by v09....thanks again & have a good one Smile
Wed, Jul 16, 2008 at 9:29:43 PM | Heavy Weight Leader Arrows
timbo89
timbo89 Avatar
4 Stars: 5 Votes
The next best thing you could do is create a "Detail Component - Line Based" family which includes your custom arrow head and leader line
Wed, Jul 16, 2008 at 10:31:20 PM | Heavy Weight Leader Arrows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes same response here.  Not currently possible in 2009.  Yes you can do workarounds using detail components but I wouldn't recommend it.  Its just more to co-ordinate.  Let Revit do the co-ordination of things like this and put up with some of its graphic flaws...
Regards,
Chris.
Wed, Jul 16, 2008 at 10:39:26 PM | Heavy Weight Leader Arrows
Luckydug
3.5 Stars: 3 Votes
Thanks for the thoughts guys..sounds like they'll have to live with the reality of wimpy arrow heads a bit longer...as for me I'll get on with life!
cheers Smile
Wed, Dec 9, 2009 at 5:01:26 PM | Heavy Weight Leader Arrows
rev2010
end of 2009, Revit 2010, still can't do it, the arrowhead is under the generic annotations line style, same as the leader line, how hard is it to make another line style in Arrow.rfa? 3 years and counting...
Fri, Jan 20, 2017 at 3:33:12 PM | Heavy Weight Leader Arrows
ccabral3
I've had this exact issue and this is all I've figured out so far.. very tedious and time consumming.. I will update when/if I figure out an easier way.
Use a spot coordinate instead of a text leader... photo 1: You gotta go into your property browser and scroll down to "spot elev symbol" open any one of those sub categories and duplicate. Type the text you want the leader to say here.... now, photo 2: make a spot coordinate, (you'll need a reference plane because it is supposed to attach to walls and whatnot.) Edit type - change leader to arrow head of your preference. change symbol to the text you just created in the project browser, and edit the line weights accordingly. Photo 3: scroll down in the type properties and change "top value" and "bottom Value" to none. AND MAGIC! pic 4: FINISHED! Unfortunately there is way too much text in my project to make a new text for every single one..
Creating Leader Arrows
Thu, May 19, 2011 at 4:09:46 PM
Breaking Leader Lines and Reverse Arrows
Wed, Oct 10, 2007 at 11:27:13 AM
very heavy project- how to reduce its weight?
Sun, Feb 28, 2010 at 11:02:38 AM
LEADER
Sun, Dec 30, 2007 at 8:37:10 AM
Change Leader line weight
Tue, Apr 29, 2008 at 1:30:01 PM
Page generation time: 2.2405
