59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> bubble callout tag
Wed, Jul 16, 2008 at 6:35:38 PM | bubble callout tag
archi3
in revit 2009
how do create a callout tag? I want create a tag to callout a section or detail, one that bubbles the area rather than showing the cut line. this way i can bubble the whole elevator and elevator lobby instead of just the cut line of the section.
Thu, Jul 17, 2008 at 3:00:41 AM | bubble callout tag
psymon
psymon Avatar
3.5 Stars: 6 Votes
I am not sure exactly what you are asking.
You can use the "Callout" command under the view menu. This will create a rectangular shaped callout with a tag attached by a leader line - is that what you mean?
The actual Tag for the callout is slected under Settings>View Tags>Callout Tags.
You can create your own then load it into the project/template then select it in the menu location above.
When you insert these callouts you also have the option to "Refernce Other View" below the menu. If you want you can cut the section, hide the tag and then put in the Bubble callout and refernce the section view.
drawing reference without callout bubble or section tag???
Thu, Jul 16, 2009 at 2:18:47 PM
Callout Bubble LWT change
Wed, Jan 9, 2008 at 4:00:50 PM
Custom Curtainwall Tag from View Tag
Tue, Feb 26, 2008 at 9:17:54 AM
callout bubble customization
Tue, Jul 15, 2008 at 8:51:37 AM
Interior Elevations - 4 callout bubbles combined to single callout bubble?
Wed, Jul 10, 2013 at 5:08:00 PM
Page generation time: 0.4621
