62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> text symbols
Thu, Apr 14, 2005 at 6:38:56 PM | text symbols
latemore
latemore Avatar
3 Stars: 2 Votes
we are recent new users and want to insert degrees and diameter symbols in text. is there a revit way, rather than the alt plus number method?
Sun, Apr 17, 2005 at 8:21:56 PM | RE: text symbols
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope... Only the character map shorcuts ATM. Which in my preference is just as easy. Most monitors in our office have a post it stuck to them with a list of the most common used symbols.
Tue, Apr 19, 2005 at 8:13:06 AM | RE: text symbols
jstewart
How can I find those if I don't have the post it!
Tue, Apr 19, 2005 at 8:24:01 AM | RE: text symbols
latemore
latemore Avatar
3 Stars: 2 Votes
latemore back. thanks mr spot. i checked it, and works fine on a normal keyboard, but not my laptop. as others may be asking for the codes, i am attaching some shortcuts.
Thu, May 31, 2007 at 1:39:19 PM | text symbols
ttdrafting
Great info, and thanks for the shortcuts. Is there anyway to use codes on a laptop?
Thu, May 31, 2007 at 3:39:19 PM | text symbols
TomDorner
4.5 Stars: 25 Votes
The codes need to be typed in on a laptop using the 'numbers' keys not the ones above the qwerty letter keys.  Some laptops have the numbers keys that can be activated with a special Fn key.  Check your laptops documentation to see if you have such a feature.  You can also add a USB num pad which should work.
Another option is to insert the characters by using a copy paste method from MS Word or by using the Windows charmap utility [Windows>Start>Run>charmap]
Tom
Text symbols [ 1 2 ]
Tue, Mar 10, 2015 at 10:14:14 PM
18
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
symbols in text
Tue, Apr 4, 2006 at 11:52:47 AM
The ability of adding text or symbols into line patterns
Thu, Oct 30, 2014 at 2:45:39 AM
Text Styles
Tue, Aug 4, 2009 at 9:59:13 AM
Page generation time: 0.5844
