65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Killing error while saving file to central
Wed, Jul 16, 2008 at 9:33:29 AM | Killing error while saving file to central
Rams
3 Stars: 3 Votes
When i do save to central it gives the error { Element 4593824 became corrupt at some time before this session}.
Everytime i have to audit and purge the central file and it works for approx. half an hour and then comes the same error with different element Id. I could delete few elements but now it showing that element do not exist anymore.
Please help as i have submission tomm....... :-(
Now on the implementation stage....
Wed, Jul 16, 2008 at 9:36:20 AM | Killing error while saving file to central
broncos4life
3.5 Stars: 11 Votes
The only way I have found to fix this type of issue is to revert back to a backup file.  What version are you using?
Wed, Jul 16, 2008 at 9:44:24 AM | Killing error while saving file to central
Rams
3 Stars: 3 Votes
We r using Revit architecture 2008.
IS there any other way to do it?
Thu, Aug 14, 2008 at 5:17:04 PM | Killing error while saving file to central
Dlas3
same problem here anybody has figured a way to fix it?
Fri, Aug 15, 2008 at 8:59:50 AM | Killing error while saving file to central
Rams
3 Stars: 3 Votes
Do continuous audit nd it will get fixed whn u r lucky :-)
GUDLUCK
Mon, Aug 18, 2008 at 1:58:14 PM | Killing error while saving file to central
Dlas3
removing a linked Revit file apparently solved the problem...have not had any more corrupted element errors in two days.....
Saving to Central
Thu, Mar 12, 2009 at 9:42:06 PM
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:27 AM
Shared Coordinates Error When Saving
Wed, Sep 10, 2008 at 1:42:10 AM
Error - Local File Resides in Central File Location
Fri, Apr 9, 2010 at 8:34:56 AM
Revit 2009 error message from linking
Mon, Sep 22, 2008 at 9:58:18 PM
Page generation time: 2.0091
