38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stairs with different riser hights.
Wed, Jul 16, 2008 at 7:16:31 AM | Stairs with different riser hights.
KingRevit
4 Stars: 12 Votes
Hi I have a stairs with different riser hights on the first step to all the others.
see image below.
how can i achieve this. i don't want to make an inplace family as i have to attach railings to the stairs. any help would be much appriciated.
Wed, Jul 16, 2008 at 7:46:55 AM | Stairs with different riser hights.
Why don't you just start the stair the 170+/- above the floor and fix the sections?  If you need to do 3D work, you could add someting in place.   The railings will still work.
Wed, Jul 16, 2008 at 8:59:52 AM | Stairs with different riser hights.
broncos4life
3.5 Stars: 11 Votes
http://www.revitcity.com/forums.php?action=viewthread&thread_id=9572
Wed, Jul 16, 2008 at 11:30:22 AM | Stairs with different riser hights.
KingRevit
4 Stars: 12 Votes
cheers wwhub. that is what i'm trying now.
Wed, Jul 16, 2008 at 1:04:28 PM | Stairs with different riser hights.
lunchtrayrider
3.5 Stars: 7 Votes
Thu, Jul 17, 2008 at 9:08:49 AM | Stairs with different riser hights.
KingRevit
4 Stars: 12 Votes
thanks,
this stairs is giving me a headace, so i have sorted out the first step by making it two stairs. but now my handrails. from the image below you will see my problem. i can't get the join to be neat it keeps missing by a few mm.
Thu, Jul 17, 2008 at 9:38:32 AM | Stairs with different riser hights.
KingRevit
4 Stars: 12 Votes
okso i got this to work, well sort of. the image looks right and it is well within tolerance but i wish revit was able to do semi automated. i will explain what i mean after i go through how to solve this incase anyone else has the same problem.
select your habndrail
edit
select the rail that isn't meeting the rest
on the options bar select height correction
and place in a figure
finish sketch
you will have to do this a few times untill you get (guess0 the correct height adjustment.
now this is where i wish revit had an option to automatically fix the the height adjustment.
thanks for all your help.
Tue, Dec 19, 2017 at 3:01:11 AM | Stairs with different riser hights.
pawelgorski
Hi there.
I've got a staircase with different riser heights. Bottom riser is 200mm high, top riser 100mm and others 150mm (refer to attached screenshot). Does anybody know how to create such stairs with different riser heights in Revit?
Tue, Dec 19, 2017 at 6:46:15 AM | Stairs with different riser hights.
Do you really have different riser heights or are you trying to incorporate the finish at the floor and the landing?  That is what I see you trying to do in your section.  I suggest you do equal risers and add detail in sections to show this at the landing.
In most areas, riser height is always shown from finish levels, not a sub base.
Stair Riser Profile
Fri, Jun 25, 2010 at 10:46:20 AM
Stairs: Hide Tread and Riser in Section View
Mon, Mar 11, 2013 at 8:36:42 AM
Getting Stairs to be level with floors.
Sun, Nov 25, 2012 at 12:32:16 PM
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:04 AM
riser stair problem
Tue, Nov 6, 2018 at 7:10:18 AM
Page generation time: 0.2557
