Forums >> Revit Building >> Technical Support >> Phasing and Room Tag
4 Posts No Rating |
Right now I have 3 phases: existing, demolition and new construction. But later I have to show the existing room tag on the demolition plan. Because the room tag is phase-specific, the only way I can figure out is merging the existing phase and demolition phase. However, after I did combination, the phase filter doesn't work well. I must use “show all” instead of “show previous and demo” to see the existing & demolition plan…it doesn’t make any sense.
Anybody knows the problem?
Thanks!
4 Posts No Rating |
nobody knows??????please help!
Room tags are view specific. You can copy them from one view to another. You have to watch out though as sometimes a room exists in one phase but not the other. Remember, Revit is a database and the room tags "report" the properties of the room not define the room.
There is a discussion of this issue on AUGI if you go over there and do a search.
Tom
4 Posts No Rating |
thanks Tom!
i checked info there,doesn't help a lot.
anybody knows more?
Post edited on 2005-04-14 19:58:21
Post edited on 2005-04-15 13:28:31
Revit will not allow you to show previous phase tags in a later phase.
Workaround:
Duplicate your existing plan and turn off everything except the room tags. Then on a sheet overlay this plan over your demolition plan (it will snap into place). This will retain all the automation of these tags and still essentially show all the information you need. For this room tag view also set the view title to none.
HTH.
IS THIS WORKAROUND STILL NECESSARY WITH rEVIT 2009/2010? I AM HAVING THE SAME ISSUE BUT FOR EXISTING ROOM NAMES SHOWING UP IN NEW PLANS FOR ADJACENT AREAS
8 Posts No Rating |
You can also just leave the existing rooms as "new construction" in the plan, and just filter them out of your new construction room schedule. I just wrote "existing" in the comments parameter of the rooms that are supposed to be existing rooms and filtered by: comments - does not equal - existing. I don't see too many drawbacks to this. Nick
" You can also just leave the existing rooms as "new construction" in the plan, and just filter them out of your new construction room schedule. I just wrote "existing" in the comments parameter of the rooms that are supposed to be existing rooms and filtered by: comments - does not equal - existing. I don't see too many drawbacks to this. Nick " Huge, Huge Danger! Other people in the process rely on rooms placed correctly for energy analysis, HVAC zoning, quantity take-offs etc. etc. If BIM is to be achived, then data centric solutions need to be employed not CAD centric solutions.
would be nice if this would get addressed. i dislike having to do a work around for this each time we do renovation project. it doesn't seem like it would be all that difficult, hey but i not a programmer.
----------------------------------- PWD |
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Phasing is interfering with Room Area/Tags (I think) |
Wed, Sep 28, 2016 at 1:15:48 PM
Keynote or Room Tag |
Fri, Feb 5, 2010 at 1:08:31 PM
