60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Texture - add a new material into library from picture
Thu, Apr 14, 2005 at 3:39:41 AM | Texture - add a new material into library from picture
rickardstark
3 Stars: 1 Votes
Please! This is the issue: I have got a picture of a material that I want to use for rendering on my building. How do I add it into Revit 7.0 material library so I can use it in the project? Please! ///Rickard
Sat, Apr 16, 2005 at 12:15:38 PM | RE: Texture - add a new material into library from picture
3DLake
I'd like to know how to do this also.
Sat, Apr 16, 2005 at 3:18:21 PM | RE: Texture - add a new material into library from picture
justinmthomas2003
I know little about that. What I do is save the picture in jpeg or bmp. Then go to setting and click material. Go into AccuRender and at the top, there are three menu. The last one is Material, click that and click new. Use Default Gray and you will go into Material Editor. There are four tabs. Click the third tab and it bring you to Image Mapping and Procedural Bumps. Click Add under Image Mapping. It will lead you to series of files. Go to the file where you saved your picture in, click the image to open. It will lead you to Image Mapping, where you edit your picture. If you want to make your image size smaller or larger it's on Main tab (The first tab of four). Then save it under User in Material Library. That's all. I hope that is answer to what your looking for.
Sat, Apr 16, 2005 at 3:19:42 PM | RE: Texture - add a new material into library from picture
justinmthomas2003
Also there's no promise that the image will look great. You'd have to play with it in Image Mapping.
Sat, Apr 16, 2005 at 4:09:00 PM | RE: Texture - add a new material into library from picture
TomDorner
4.5 Stars: 25 Votes
One thing to be aware of in trying to use a picture for material mapping is to make sure that you make a "seamless tile" out of it. Seamless tiles are constructed so that you will not see the "seam" as the tile is arrayed in your rendering. Depending on your image, Photoshop can be used to make the image seamless. A Google search will bring up many tutorials on the subject. Tom
Texture - adding new into matrial library from picture
Mon, Oct 10, 2005 at 5:51:42 AM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Spanish Style Tile Roof
Thu, Jul 18, 2013 at 11:53:38 AM
Help me! Lack of BMCD2AR3 material library in revit building 8.
Sat, Oct 8, 2005 at 9:54:16 PM
New material - my attached picture disappear
Sat, Jan 30, 2010 at 4:22:52 PM
Page generation time: 3.6120
