64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Texture - adding new into matrial library from picture
Thu, Apr 14, 2005 at 3:35:21 AM | Texture - adding new into matrial library from picture
rickardstark
3 Stars: 1 Votes
Please! This is the issue: I have got a picture of a material that I want to use for rendering on my building. How do I add it into Revit 7.0 material library so I can use it in the project? Please! ///Rickard
Mon, Apr 18, 2005 at 3:57:50 AM | RE: Texture - adding new into matrial library from picture
fazerneil
4 Stars: 5 Votes
Place jpeg/bmp in Revit rendering/materials folder. (application data/autodesk/revit_?/rendering/accurenderredist/support/material) (? is version of revit you are using) Go into revit/settings/materials. Select any material and duplicate. Give it new name In Accurender-material box select arrow Right click any existing material and select New/Default Grey Go to maps tab, and Add Go to above location and select your material OK twice and save as a User material You will need to play around with scale etc to suit project settings etc within the map dialogue box (after selecting material)
Fri, Oct 7, 2005 at 12:08:37 PM | RE: Texture - adding new into matrial library from picture
Will9000
4 Stars: 5 Votes
how do you adjust the scale??
Fri, Oct 7, 2005 at 5:07:20 PM | RE: Texture - adding new into matrial library from picture
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In accurender, edit the material, edit the map, in the first tab there is a scale dimension (in metres) that it uses to define the size of the sample. hth.
Mon, Oct 10, 2005 at 5:51:43 AM | RE: Texture - adding new into matrial library from picture
Will9000
4 Stars: 5 Votes
Sorry to be a pain, quoting "In accurender, edit the material, edit the map, in the first tab there is a scale dimension (in metres) that it uses to define the size of the sample." ive tried modifing the scale but is just doesn't appear to work, can you let me know if i am in the right direction with the attached, i have posted another thread "scaling Jpegs for render scenes" and i have tried fazerneil's method but that doesnt appear to work either, any fool proof help be much appreciated, thanks
Texture - add a new material into library from picture
Sat, Apr 16, 2005 at 4:09:01 PM
user material library
Wed, Nov 7, 2007 at 10:14:36 AM
Picture as texture?
Wed, Aug 13, 2008 at 7:36:11 AM
Texture Mapping at the Corner
Mon, Sep 17, 2012 at 11:21:52 AM
Texture patterns render black
Thu, Apr 14, 2011 at 9:14:45 AM
12
Page generation time: 4.0090
